i'm not sure.
Is your water distilled?
yep
What is the secondary resistance?
1.1 ohm, primary is 2.2 ohm
Are you using a diode? (you mention positive and negative)
ultrafast diode after donut before outside plates
Is the secondary getting hot?
donut heats after five minutes of over 2 amps at 150v dc pulsed at any frequency, stays cool under one amp at 150dc pulsed, 1/3 lpm by bottle displacement at 2 amp & 150vdc
What wire is used on secondary ? in mm or awg
16 awg silver plated stranded one layer 360 deg
note, 20 awg silver plated stranded as four layer 360 degree primary over that
Any gas on the cell?
see above
How may amps on the primary?
variable, max voltage is reached at around one amp
Frequency? 12.5khz
PRimary voltage? 150vdc
Primary and secondary inductance?
PI is .7mH
secondary inductance is 17.2mH
Please answer all this questions as i can valuate whats happening.
If is distilled water could be a kind of resonance or your circuit behaving as open circuit
If the water is distilled and wire is small you may have what i call voltage transformation according to ohms law in the transformer or in the wire.
If you are stepping down the voltage you are stepping up the amperage. And more amps * resistance = voltage.
wait for your answer
