Author Topic: Resonance WFC  (Read 8131 times)
Offline Hidden
Re: Resonance WFC
« Reply #10 on: January 21, 2010, 14:36:55 pm »
Good stuff webmug
The RVIC setup may not be resonant, but it did run the dune buggy, so the merit is there. Also we don't know what is in the control box for the RVIC set up, so there is much to learn there as well.
back to the topic of the resonance wfc, the insulation is there to eliminate "voltage coupling" to water bath - not just current coupling... meaning you want the electric field from the tube to be contained in the delrin and focused in the cavity, the point being, I am under the impression that the delrin should be sufficiently thick, and that a thin casing my not prevent the so-called "voltage coupling" to the water bath. This may or my not be an important factor in the design of the cell, it won't stop you from reaching resonance.... but it is something that may be of value.
Offline Hidden
Re: Resonance WFC
« Reply #11 on: January 21, 2010, 14:56:36 pm »
That picture I posted, those two parts would be made out of delrin with a 3" OD, there is a 1" hole for the outer tube 3" long, with this you can choose any gap you want by the thickness of the outer tube and then you can see the half inch holes for the longer 1/2" inner tube. So it will be a completely incased and insulated cell. I've made mental adjustments to my design to make it simpler, and to set it up for a water pump to force water through the bottom. Also a 3" OD acrylic tube will mount on the top of what is shown, for gas viewing, and then a simple delrin cap on top of that. For the electrical connections I'll just do it like Dynodon mentioned, a bolt that goes in and touches the side of each tube.
Have you seen Dynodon's Cell? It's a nice cell and a good example. When do you plan on having this cell running?
For the resonance part...Stan writes that the cavity can resonate at a multiple numbers of frequencies (harmonics) so there is not one.
br,
webmug
Where did you read that again ?
Plz quote me this document .
What I mean due contaminants in the water the frequency is not one. Stan calls this "harmonic effects". These are different frequencies (bandwidth).
"Because resonances of different waters, water volumes, and capacitor cells vary, the resonant scanning circuit of Figure 8 is useful. The scanning circuit o Figure 8 scans frequency from high to low to high repeating until a signal lock is determined. The ferromagnetic core of the voltage intensifier circuit transformer suppresses electron surge in an out-of-resonance condition of the fuel cell. In an example, the circuit scans at frequencies from 0 Hz to 10 KHz t 0 Hz. In water having contaminants in the range of 1 ppm to 20 ppm, a 20% variance in resonant frequency is encountered. Depending on water flow rate into fuel cell, the normal variance range is about 8-10%. For example, iron in well water affects the status of molecular disassociation. Also, at a resonant condition harmonic effects occur. In a typical operation of the cell with a representative water capacitor described below, at a frequency of about 5 KHz at unipolar pulses from 0 to 650 volts at a sensed resonant condition into the resonant cavity, conversion of about 5 gallons of water per hour into a fuel gas will occur on average. To increase the rate, multiple resonant cavities can be used and/or the surfaces of the water capacitor can be increased, however, the water capacitor cell is preferably small in scale. A typical water capacitor may be formed from a 0.5 inch in diameter stainless steel rod and a 0.75 inch inside diameter cylinder that together extend concentrically about 3.0 inches with respect to each other.
Shape and size of the resonant cavity may vary. Larger resonant cavities and higher rates of consumption of water in the conversion process require higher frequencies such as up to 50 KHz and above. The pulsing rate, to sustain such high rates of conversion must be correspondingly increased.
From the foregoing description of the preferred embodiment, other variations and modifications of the system disclosed will be evident to those of skill in the art. "
patent WO1992007861A1.pdf
br,
webmug
Offline Hidden
Re: Resonance WFC
« Reply #12 on: January 21, 2010, 15:28:03 pm »
 It would be simpler to design a system that will turn a little pot nob no ? 20% is not far away ? How fast does tht lock need to be ? It aint fast with all those cmos chips thats 4 sure , that circuit needs an update for 74hc . IMO There is no resonance changing in a single pulse train burst , that circuit would never have the speed for that kind of rapid change  . Its more a long term thing is what I'm trying to say .
It seems like harmonics is more cause and effect , the resonance is always in a range of 20% frequency .
Offline Hidden
Re: Resonance WFC
« Reply #13 on: January 21, 2010, 16:22:43 pm »
Yes, but Stan writes this as an example...
"From the foregoing description of the preferred embodiment, other variations and modifications of the system disclosed will be evident to those of skill in the art. "
Seriously, the electronics used are almost 20 years old, these can be better/faster build.
Didn't Stan made the circuits the KISS method?
A frequency generator with a POT is not a KISS method for keeping it in resonance, I don't want to adjust the thing all the time manually, when you have multiple cavity cells. 8)
br,
webmug
Offline Hidden
Re: Resonance WFC
« Reply #14 on: January 21, 2010, 16:50:03 pm »
New thought for a 4 tube cell. Then again the delrin thickness between tubes *might* be too thin for proper isolation and insulation.
