Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 10470 times)
Online Hidden
« Reply #110 on: October 08, 2011, 10:44:32 am »
After looking at the video, i was wondering the following.
Do you run that big engine on petrol and you are adding the fog?
Hi Steve
  That is correct, gm 305 tbi running on gasoline with the fogger piped into the air filter cover above the TBI unit. Last night was the 1st time I saw any real DC coming from the extraction circuit. Not very much at all really, but it's a start. Hope to repair inverter today and test some on road action.
It will be a challange to find out if you would get more power out then in....
To be honest, i am not sure if thats the goal....
Ionize steam. Use hv and uv.
Tutanka wrote today that if you add a little bit of hho that you might get a better result....
Online Hidden
« Reply #111 on: November 02, 2011, 02:57:12 am »
Have you thought about trying infrared? I think more of the light would be absorbed
Offline Hidden
« Reply #112 on: December 16, 2011, 16:18:30 pm »
Thank you Dave for the suggestion and yes I thought about infrared but could find any high power modules. I recently found 5watt infrared LEDS at 850nm and 940nm spectrum. I'm waiting for them from China. I'll keep everyone posted.
Here is the ebay link to a supplier.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180774998032
Offline Hidden
« Reply #113 on: December 24, 2011, 16:50:45 pm »
Pic show water fog mist is equal to wavelength of fog droplet. www.scaleofuniverse.com
 Particle collision is helping free electrons to outer ring so that they may be consumed in the electron extraction circuit. In this pic you will notice the water mist droplet to be the same size as the wavelength as the infrared spectrum. So I imagine a very high pulse rep along with high intensity bombardment of the water fog with have some excellent outcomes with assisting in the destabilization of the water molecule.
