Author Topic: High Voltage Circuit (VIC)  (Read 2361 times)
Offline Hidden
Re: High Voltage Circuit
« Reply #10 on: November 18, 2009, 22:07:32 pm »
A little update,
I have tested resonance on my STEP-UP transformer coil, here are a few scope shots...
As you can see, my PULSE signal is not perfect and you see a little ripple on the secondary coil output signal.
One coil 2x90 wnd primary 22AWG / 2x1000 secondary 26AWG center tap no s/s core used, when used more amps are drawn.
Basic configuration:
Primary 2x90 series connected (180wnd) 22AWG
Secondary 1x1000 connected 26AWG
Upp in=15V DC PULSE
du=~55%
I in=0.3-0.44Amps
resonance frequency = ~126kHz
Upp out=~650-690V
This is just a little test to see what happens when resonance occurs, guess most people here already have seen it.
Can someone explain the DIODE used as a frequency doubler? ;D
And what could happen when this signal is going into the bifilar choke?
br,
Webmug
Offline Hidden
Re: High Voltage Circuit (VIC)
« Reply #11 on: November 23, 2009, 21:14:11 pm »
Ok,
I connected a bifilar choke to secondary winding. In-between a diode.
When STEP-UP coil is in resonance, AC signal is generated, see above.
First I had no core in the coils, AC signal is generated on resonance frequency... So now inserted a few SS rods into the STEP-UP transformer. Generates a AC signal, different resonance frequency.
Then connected a separated (other core) bifilar choke with a few SS rods (need more, but takes time to cut). PULSE duty-cycle +50% GATE duty-cycle +100%... AC signal at lower resonance frequency!
Now adjusting the GATE duty-cycle +30% low frequency...as you can see, there is little step-charge and a big current generated in the OFF GATE PULSE!!! My current is 0..30mA @15V. FL lamp is ON.
Don't know at this moment why there is still AC signal on the WFC, assuming there must be DC step-charge???
I think that my choke has low resistance. Need to make one with smaller wire and more windings.
Nice to see this effect.
Update:
Add picture of my choke L1-L2 bifilar, I made two of them. Top one was connected.
Br,
Webmug
« Last Edit: November 24, 2009, 13:31:17 pm by webmug »
Offline Hidden
« Reply #12 on: November 23, 2009, 22:41:56 pm »
webmug,now your seeing what I'm seeing.An AC sine wave when at resonance.
I am generating the same kind of signal,but at 4kv peak to peak.
Offline Hidden
« Reply #13 on: November 23, 2009, 23:06:06 pm »
that would be the right waveform if it was rectified? (light blue) is the diode not keeping it DC?
i understand the voltage is not acting as expected... but I'm wondering how to fix it?
I noticed with the 3 phase rotary vic, your voltage will have an overlap, so this will (should) inherently prevent it from swinging past ground as the next phase caries it over
Online Hidden
« Reply #14 on: November 23, 2009, 23:08:46 pm »
Ok,
Now adjusting the GATE duty-cycle +30% low frequency...as you can see, there is little step-charge and a big current generated in the OFF GATE PULSE!!! My current is 0.30mA @15V. FL lamp is ON.
Br,
Webmug
Thanks for sharing these nice scope shots, Webmug!
