Author Topic: Water Injector  (Read 1712 times)
Offline Hidden
Re: Water Injector
« Reply #5 on: September 30, 2010, 03:35:41 am »
Here's the finished test injector
Online Hidden
Re: Water Injector
« Reply #6 on: September 30, 2010, 15:05:03 pm »
Hardkrome,
What kind of solution have you made for the small valves for blocking gasinput when the pressure get on on the compression stroke?
Offline Hidden
Re: Water Injector
« Reply #7 on: October 01, 2010, 01:30:18 am »
I put a check valve in the cavity going down to the cavity the gas goes into, behind the nozzle disc. The theory is that with just pressure on the injector you should be able to send the mist thru it and it should break down and ignite at the tip without the compression on the cyllinder.
I'm at the point where I can get it to break appart the water and burn at the tip, not explode. I still need to make it stronger. It for sure will blast a hydrogen/oxygen mixture if I was to try that.
But the key to that lies within being able to sucessfully break the water bath appart.
Offline Hidden
Re: Water Injector
« Reply #8 on: October 03, 2010, 07:19:48 am »
How does the negative voltage work here... if the injector is grounded to the engine, will it only apply a positive voltage?
Offline Hidden
Re: Water Injector
« Reply #9 on: October 03, 2010, 19:55:09 pm »
The taper cavity acts and performs like a resonant charging choke. He talks of the mixture as acting like Micro capacitors thru the cavity.
 The negative SS voltage should be a reflection of what what the positive charge is, NOT ground. (atomic restructuring because of the water there between, in the metal)  The SS will polarize to a negative or positive voltage and hold so much charge.
 Remember that the SS negative part of the injector is "acting" like a resonant charging choke, because of the atomic structure and shape. So think of the SS part as if it was a coiled choke.
