we pushed 6 pcs of some vibrational dampening material like soft rubber between the cylinders(3 in the top and 3 in the bottom)
Quote from: Hidden on June 30, 2009, 22:54:24 pm we pushed 6 pcs of some vibrational dampening material like soft rubber between the cylinders(3 in the top and 3 in the bottom) vibrational dampening material? would you rather suspect that an arrangement with minimum dampening characteristics would have better results?With a tuning fork, it is fixed at one end, when you vibrate it and touch rubber it will dampen out quickly, when you touch metal it will continue to ring. (and when you dip it in water it splashes like crazy!) I suggest a metal structure to hold the tubes secure yet still able to vibrate. it should provide better characteristics than rubber mounting.
Im continuing with this project I'm making , stephen meyers dual synchronised 3 phase analog driver @ 24 volts .
