Author Topic: water injector tests  (Read 918 times)
Offline Hidden
Re: water injector tests
« Reply #10 on: September 16, 2009, 03:04:11 am »
Warp, glad to see you are busy with other things . This waterfuelcell stuff will make you angry .
Keep it low-tech , keep it free . Have good times with the family .
The electrical is coming , it will be my duty that all members have my circuit , no matter how little money they have .
Offline Hidden
« Reply #11 on: September 16, 2009, 12:35:48 pm »
question to all about the water injector,
i have been thinking a little about the injectors lately and i think i
have a interesting idea that may have not been noticed or mentioned..
Stans setup had the water mixing with the non combustable exhaust, and
high energy state ambient air... once mixed they would be pumped through a
constant displacement pump into whats called the fluid manifold then is
gated into the injectors from there... if we know that heat creates a
higher efficiency in production.. could this fluid manifold be a spot for
the heating of fuel gas before entering the injectors? since wouldn't Stan
look for every aspect to combine and create the most effective process.. i
see him incorporating the manifold in the or by the exhaust to help
conserve wasted thermal heat in the process
Very interesting info outlawstc.
So Stan heated the water he sent to the injectors?
What about the HHO cell?
I like it; pump that waste heat back into the combustion process!
See below: :)
I think the reason for the water injector (probably hot water) is that
Stan was using this effect:
http://www.geocities.com/waterfuel111/water_explosion_menu.html
Which works better if you have water between the electrodes rather than mist.
I think the reason for the hydrogen may have been this:
http://www.lateralscience.co.uk/AtomicH/atomicH.html
http://forum.hydrino.org/viewtopic.php?f=10&t=57
http://pages.csam.montclair.edu/~kowalski/cf/289naudin.html
http://pesn.com/2005/06/26/9600116_Naudin_MAHG/
Although it looks like pure hyrdogen is used by spraying is at the arc?
The diatomic Hydrogen then also burns; adding its energy/heat
Perhaps the combined effect of the 2, along with the heat of compression
worked to Pyrolyse the now mist mixture at the time when it be most
needed!?
http://en.wikipedia.org/wiki/Pyrolysis
This meant that the whole mixture burned due to the combination of these 3
effects and that Stan simply used a std Electrolyser for the bit of
hydrogen required.
Perhaps he simply diverted peoples attention to the cell to safeguard the
real process!?
(Guys I realize that it says a lot if one has done some experimentation of
your own and posted the project, but some small acknowledgement of my
existence would be nice! :)
I do not have the space for my equipment, or the money to experiment
myself at the moment. :( )
« Last Edit: September 18, 2009, 14:09:21 pm by Steve »
